stahl folder b20
Discussion in 'Folders' started by kahlil, Sep 18, 2015.
  1. kahlil
    kahlil New Member
    Sep 2015
    florida U.S.
    Folder powers up properly but delivery wont go on or move. I replaced the motor and still no luck. Any idea how to fix?
  2. PostroomOnline
    PostroomOnline Member
    Oct 2015
    5
    Rushden, Northamptonshire, England, United Kingdom
    Hello I'm guessing I might be a bit late but I've only just joined,
    Did you manage to resolve this in the end?
  3. Brian Mariani
    Brian Mariani New Member
    Aug 2018
    Orlando, Fl
    Not sure if this is where I post a question. I have a Stahl B20 and when I power it gives me an error 14 code. I can not find it in the manuel. HELP HELP Please
  4. CHOCK
    2,387
    Hi:
    Do the following:
    1) Turn off the machine
    2)Unplug the folding station and/or deliveries from first station
    3)Plug a blind/dummy plug into the first station.
    4) Turn On the machine, and restar the equipment
    Finally:
    Perform a visual inspection :
    look for loose and broken wires, improperly seated connectors, loose or broken wires, jam switch
    fuse, double sheet detector.fuses or feed button contacts.
    Use the schematic diagrams
  5. desmonddmw80
    desmonddmw80 New Member
    Nov 2019
    malaysia
    hi , everyone know stahl KD78 , when power on the display just show the error code 55 ...?
    HamedNDIAYE likes this.
  6. CHOCK
    2,387
    Please take a measure in the power supply electronic for:+5Vdc +24Vdc Led H3+H4 must be ON.
    2) if the power supply in tolerance in 3% up or down, take out the EPROM, clean the pins with carefully, using Anti Static device, and try again.
    if the problem persist, EPROM with Software is defective.
    3) However look for loose wire in the panel control and tight very wel..
  7. desmonddmw80
    Nov 2019
    malaysia
    Hi ... thanks a lot .... i will try later ...
  8. CHOCK
    2,387
    Did you fix it?
    Let me know.
    Blessing
