Spot UV coating
aqazi81
2009
827
KARACHI PAKISTAN
Hi Guys,
We are using a single color Roland rekord for UV coating our jobs. We want to do spot UV coating on the press but we dont know how to do it....plz help..
There a couple ways to do that.Cheapest is to use blanket and cut on the place where you don't need uv varnish in jobs where you don't need perfect fitting and are not tpo problematic for placing spot coating.Sometimes we use polymers of parts that has to be coated and we glue them on the blanket of varnishing machine so uv varnish is applied throughout polymers only on places the spot coating has to be.The most expensive (and best quality) way is with plates for uv varnishing .
  • We want to make some gloss effects on some jobs ..... like on company logos or some motifs.... what type of polymers?
    We use polymers from Flint NYLOPRINT WF80H,we have separate machine for UV varnishing and results are very good,and when we need perfect register we use plates.
    What type of plates are used for UV spot coating?
    What type of plate making equipment is needed for the Nyloflex plate?
    You can cut them by hand or on plotter if you had one.At the moment we us e plates from Nessmann STRIP PLATE® POLY we cut them by hand and they are very,very good and cheaper.Here is their web page and instruction it is easy to use them and they last very long no problems they fit on almost any sheetfeed machine. http://www.strip-plate.com/internet_uk/start.htm
    Thanx alot Saso for the help......I'll check that out.....
    No problem Agazi81 whatever information you need you can contact me here.
    Hello Qazi
    well.. if you are in karachi. then digital process, in korangi industrial area can help you. we are also using single color roland for UV, and we tried this UV plate, but the gloss result was on the low side,
    if you can afford. you can get best spot uv result with silk screen/screen printing.
    @ faizeej.... yes I am form Karachi... well there are some printers that do offer Spot UV, but we wanted to do in-house.
    I always create a seperate file for my varnish plates. I select a spot color that is NOT used in the document, and make everything I want with a varnish on it that color. then delete everything I don't want. I normally use an orange color for gloss varnish, and a purple color for dull varnish (personal preference).
    Qazi
    Make a flexo plate from digital process or somewhere else. I guess. there is one at pakistan chowk, i dont remember the name.. then you place that flexo plate on your roland machine.. then try.. you can do spot UV. but the result will be lesser than screen printing spot UV.
    if you still need help, cal me at 0333-2358831, i will try my best.
  • Hi everyone, i´ve reading all your post, i had the same problem, i´m from mexico, and i would like to thank you all for the help, thanks a lot, best regards!!!!
    Wow, it is my 1st time to know that we can use offset printing machine to do spot UV.
    We mostly do spot UV via silk-screen printing.
