jetscreamer
- 2009
- 146
- Kenilworth australia
Hi is there a way to export my custom colours from spot master into colour pilot?
Cheers
Cheers
6k label, at the moment I'm taking a pic of my spot master colour settings and transferring them to colour pilot. Just wanted to know if there is a way fo it automatically?Which Indigo
Do you sell HP Indigo supplies (such as PIP or Blanket)?So I found out from HP that if you close colour pilot then make your spot master corrections and print the job, then open colour pilot the colour corrections will be updated in the appropriate colour strategy.
No sirDo you sell HP Indigo supplies (such as PIP or Blanket)?
Is that spot master different from Colour Pilot? what's the difference between them? I've only used Color PilotSo I found out from HP that if you close colour pilot then make your spot master corrections and print the job, then open colour pilot the colour corrections will be updated in the appropriate colour strategy.
Spot master is used on the Indigo and color pilot it at the dfe.Is that spot master different from Colour Pilot? what's the difference between them? I've only used Color Pilot
