Speedmaster XL75 touch screen
Discussion in 'Heidelberg Printing Presses' started by bLuuR, Jan 3, 2020.
  1. bLuuR
    bLuuR Member
    Jan 2020
    28
    Slovenia
    Hello.
    I'm new to this forum, so far it looks great, lot of useful threads. Thank you for this
    I hope someone can help me with my problem. On our machine Heidelberg speedmaster XL 75, touch screen at infeed and delivery won't work. Sometimes work, sometimes don't work.
    I alredy figure it out it's the problem with touch screen (borowed from another press and it worked ok). Before I order new touch screen I would like to try doing calibration on this touch screen, maybe than it will work.
    I looked on screen and didn't find any button for calibrate except 3 pin jumper on touch screen electronic (see picture bellow).
    Does anyone know how to calibrate this screen?
  2. CHOCK
    3,058
    1)Attached is there the steps for calibration Touch screen Display for Heidelberg Xl75
    You do not need to touch any pin jumper.
    2) However you must test the Leds H2-H5: H2- Green =On interface supply is ok. H3- green =Flashes quickly H4-Green=ON power supply good H5-Green=Inverter Voltage for back-light is o.k
  3. bLuuR
    bLuuR Member
    Jan 2020
    28
    Slovenia
    Thanks.
    Thought it is more complicated ;)
    I made a screen calibration, at the moment it works normal without problem. Hope it stays this way.
  4. CHOCK
    3,058
    enjoy it
  5. bLuuR
    bLuuR Member
    Jan 2020
    28
    Slovenia
    Have to order new touch display it stopped working in a day. Calibration didn't help at all.
  6. CHOCK
    3,058
    You said before:
    "I made a screen calibration, at the moment it works normal without problem. Hope it stays this way"??
    If stopped working a day, Is NOT your fault, you must understand that everything has determined working life.
    Sorry for to order new touch display.
