Speedmaster 74/4 1993 error
Discussion in 'Heidelberg Printing Presses' started by Nicola, Apr 8, 2025.
  1. Nicola
    Nicola Member
    Mar 2018
    36
    Padova
    Hello, I have the following error on a 1993 Speedmaster 74/4. Now the machine does not run. What could it be?
    Help me
  2. Adil
    Adil Senior Member
    Nov 2021
    1,319
    Casablanca
    It can be variant key problem please check your variant key sir
  3. Nicola
    Nicola Member
    Mar 2018
    36
    Padova
    THANK YOU, I don't know how to check the fault. The command displays remain OFF. Also in the 2 steps in the photo the LEDs are off. Is this correct?
  4. Adil
    Adil Senior Member
    Nov 2021
    1,319
    Casablanca
    In the second picture the led of the two ntk board must not be off , try to check connexion , supply voltage or repair the board if it s defective .
    Good luck
  5. Nicola
    Nicola Member
    Mar 2018
    36
    Padova
    Thanks for your reply. It could be a power supply problem. I think it is 24V, I thought some fuse. But I can't figure out where the board's power supply is. I don't have any wiring diagram.
  6. Adil
    Adil Senior Member
    Nov 2021
    1,319
    Casablanca
    You can test with the same down ntk in the cabinet to know if it s board issue but check first if there is a short circuit
  7. Nicola
    Nicola Member
    Mar 2018
    36
    Padova
    good morning it seems that ntk goes to 0V input. I checked the GRM24 board: Input 26V x 3 phases, output 0V (0.013V)
  8. Adil
    Adil Senior Member
    Nov 2021
    1,319
    Casablanca
    You can test with the same down ntk in the cabinet to know if it s board issue but check first if there is a break circuit
  9. Adil
    Adil Senior Member
    Nov 2021
    1,319
    Casablanca
    You can repair the grm board
  10. Nicola
    Nicola Member
    Mar 2018
    36
    Padova
    Ok Thanks. There is a three-phase diode bridge rectifier. Input is 24 V AC. According to the calculations it should output 32 V DC, isn't it too high to power the NTK board? Does NTK have a 30DC to 24VDC stabilizer? Thanks
  11. Adil
    Adil Senior Member
    Nov 2021
    1,319
    Casablanca
    I will send you the power on the grm board , it s not the same
  12. Nicola
    Nicola Member
    Mar 2018
    36
    Padova
    ok thanks
