we are having problems with marking on printed image looks like the sheet is hitting on something between units,cleaning transfer cylinders resolves problem only sometimes,am new to press
Use superblue on the transfer drums???
make sure your tail vacumn is working and set to the correct lenght of sheet also check the eye between units with a clean white cloth to see if the sheet is slapping against it after release from hold down vac.
after tracking down your marking problem you can place rubber bumpers on the transfer cylinders in the area that would be covered by the sheet in a non image area. i like to use little strips of the foam tape thats used under the ink fountain foils. putting these bumpers on the transfers will support the sheet in the troublesome areas and get you through a job. remember to remove the bumpers after your done running that form
