Shivananda
- 2023
- 6
- Manipal
Machine stops while running in stright mode,there is no error in cpc and display please help...
Dear Sir,What is the model year? If CPTronic, you should be able to scroll through "Dynamics Test" history to attempt to find cause.
Dear Sir,
Thanks for your reply..
Machine model year-1991
In dynamics Test 1 SBM_ 1/2 -7FFB and MOT- 7DFF both are flashing.
Good afternoon, can you eliminate the errors? Now the panel shows the error!S-BLT COM ------------BFFF: MSK SEND SIGNAL MESSAGE FALSE, OF STOP IMPRESSION
S-MOT -------------------FFDD Motor of Voltage excede gamma of permissible tolerance, look for HWI.
Check safety finger bars...if that are totaly clean no ink acumulated, if they are on the right position, check the sensors toMachine stops while running in stright mode,there is no error in cpc and display please help...
