Sormz oil circulation
Sunilvaryani
2018
97
Ghana
Dear sir
I'm having a 2 colour sormz 1988
Model and need to know the oil
Circulation button needs to be
Continuously pressed for the oil
To circulation in the machine
Or it's intermittent pressing is ok
Also is it supposed to make a sound to
Know if it's working or not or we need to check the oil motor
But the oil goes down as we run the press
Sunil Ghana
233 244 357677
Sounds all in order. Manual recommends pushing in oiler once per shift. When you hear the “growl”, that means oil has reached manifolds and its job is done.
  • Sounds all in order. Manual recommends pushing in oiler once per shift. When you hear the “growl”, that means oil has reached manifolds and its job is done.
    Hi sir
    I'm not hearing the growl when I push
    The oil knob for the central lubrication
    On the sormz
    But when I press the knob and realise
    It immly I can hear the hissing sound
    Of the oil
    Pls advice
    Regards
    Sunil varyani
    Sounds normal to me. Once you hear the “growling”, that means it’s completed its cycle.
