ndprinting
This sale is for a 1 year old HP CM6040f MFP with booklet maker
Main Specification
General
Device Type Fax / copier / printer / scanner
Fax Type Plain paper
Printing Technology Laser - colour
Monthly Duty Cycle (max) 220000 impressions
Width 70.4 cm
Depth 63.5 cm
Height 119.4 cm
Weight 144.9 kg
Localisation English / United Kingdom
Memory
Standard Memory 512 MB
Max Supported Memory 1 GB
Hard Disk Drive 80 GB
Copying
Max Copying Speed Up to 40 ppm (mono) / up to 40 ppm (colour)
Max Copying Resolution Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Document Enlargement 200%
Max Document Reduction 25%
Maximum Copies 999
Automatic Duplexing Yes
Printing
Max Printing Resolution Up to 600 x 600 dpi (mono) / up to 600 x 1200 dpi (colour)
Max Printing Speed Up to 40 ppm (mono) / up to 40 ppm (colour)
Printer Drivers / Emulations PCL 6, PostScript 3, PCL 5c
Scanning
Optical Resolution 600 dpi
Grey Scale Depth 8 bit
Fax Machine
Max Transmission Speed 33.6 Kbps
Fax Resolutions 300 x 300 dpi
Fax Machine Features
Broadcast Transmission 100 stations
Features Automatic redialing
Document & Media Handling
Max Original Size A3/Ledger (297 x 432 mm)
Original Type Sheets
Document Feeder Capacity 50 sheets
Max Copy Size A3/Ledger (297 x 432 mm)
Min Copy Weight 60 g/m2
Max Copy Weight 220 g/m2
Supported Media Type Transparencies, envelopes, plain paper, cards, labels
Standard Media Capacity 2100 sheets
Max Media Capacity 2100 sheets
Output Trays Capacity 500 sheets
Document & Media Handling Details ADF - 50 sheets ? 4 x input tray - 250 sheets ? Input tray - 500 sheets ? Input tray - 100 sheets
Finishing Equipment
Stacker Optional
Stapler Optional
PC Connectivity
PC Connection Availability Yes
PC Connection Hi-Speed USB, Ethernet 10 Base-T/100 Base-TX/1000 Base-T, USB host
Operating System Support MS Windows XP, MS Windows 2000, MS Windows Server 2003, Apple Mac OS X 10.3, Apple Mac OS X 10.2.8, Apple MacOS X 10.4 or later, MS Windows Vista
Power
Power Consumption Operational 920 Watt
Power Consumption Standby 230 Watt
Power Consumption Sleep 24.5 Watt
[/SIZE]
Main Specification
General
Width 70.4 cm
Depth 63.5 cm
Height 119.4 cm
Weight 144.9 kg
Memory
Copying
Maximum Copies 999
Printing
Scanning
Fax Machine
Finishing Equipment
Stacker Optional
Stapler Optional
PC Connectivity
Power
[/SIZE]
