Baron Wang
- 2026
- 11
- Shanghai, China
For small black text on packaging, check the separations before trying to make the black darker. A swatch name is not enough to tell you which inks will print.
K-only black uses no cyan, magenta or yellow; a solid K-only object is C0 M0 Y0 K100. Rich black adds other process inks. When the inks forming a small letter do not align, colored edges can appear. K-only removes that particular multi-ink registration risk within the letter, but it does not guarantee sharp print under every condition.
A large black panel is a separate decision. Ask the converter to confirm the black build and ink limits for the actual material and process. I would not copy a rich-black recipe from another printer into every black object. White text reversed out of a dark panel also needs its own review.
On the final exported PDF, inspect the smallest positive text, fine rules, large panels, and reversed lettering separately. Confirm intended separations and overprint/knockout behavior, then tie the approved file revision to the proof or sample.
PrintNinja's explanation of the small-text registration issue: https://printninja.com/standard-black-vs-rich-black/
Disclosure: I work with Shuhai Printing. Our illustrated packaging explanation is here: https://www.shuhaipack.com/blog/100k-vs-rich-black-packaging-text/
How do you communicate these separate black requirements to designers without having one global black swatch overwrite the small text?
