SM74 Main motor problem
Rabin
2025
15
Kathmandu, Nepal
Hi, here to give you some trouble.
I'm having a weird issue on my Heidelberg SM74 4 color. It's been couple of days facing this. Machine isn't inching or running, makes a warning beep and when I go to inch, it tries to but doesn't inch at all. Also doesn't show any fault or warning on the screen. When I insert crank handle doesn't make noise and can't turn with handle too. Only after pulling brake, it turns with inching or handle.
Any professionals or who had similar problem in the past, with your suggestions are appreciated.
Hi Rabin
What is the age of your machine? It seems the brake control circuit has damaged .
  • So I'm quite sure UVM4, the module controls brake is defective. Order one from China or get this one repaired.
    Good luck
