SM74 Drystar 2000 error 1609
Discussion in 'Heidelberg Printing Presses' started by Prodip, Dec 5, 2023.
  1. Prodip
    Prodip Member
    Nov 2023
    5
    Uk
    Dear sir,
    please help.
    the IR light turns off after a while the 1609 error comes to the dryer, if I turn the IR off and on, then the IR light turns on for a while. then again off IR light.
    please help me, how I am solve this problem.
  2. Mathew
    Mathew Senior Member
    Apr 2010
    635
    Kolding-Denmark
    Hi,
    Check blower -M90 if it starts once the lamps are ignited.
    Check the hose connection to dryer slide-in unit +E2 for tears and secure attachment.
    Check differential pressure switch -B110 (behinde electric cabinet lid)
    Take out the slide-in unit, clean it with blast air and put it back.
    Let us know if you still struglle with this problem.
    Good luck.
    Prodip likes this.
  3. CHOCK
    3,092
    Please test the Air supply cooling radiator with trouble:
    Air supply for cooling
    the radiators in dryer
    slide-in unit +E1 is
    insufficient or
    non-existent.
    D Differential pressure
    switch -B90 has
    been tripped.
    D Check the auxiliary
    contact of motor
    circuit breaker -Q90.
    Prodip likes this.
  4. Prodip
    Prodip Member
    Nov 2023
    5
    Uk
    Dear sir,
    We are Check air pipe, air is ok. Motor circuit breaker Q90. When IR light is on Q90 magnetic conductor on. After few minutes This Error come and than IR light off. Than rest error than IR light on. Today i am short/Connected D Differential pressure
    switch -B90 two terminal than not come this error and machine run Normal way. That time i am check D Differential pressure switch -B90 by multimeter, (Common)3 and 2(NO) switching properly. when Q90 magnetic conductor and motor ON.Please see the photo.Could you please give me the 3 Differetial pressure Switch variable Valu!
  5. CHOCK
    3,092
    Check:
    Check motor circuit breaker
    -Q90
    D Check blower -M90
    D Check the hose connection
    to dryer slide-in unit +E1 for
    tears and secure
    D Check differential pressure
    switch -B90
  6. Adil
    Adil Senior Member
    Nov 2021
    1,376
    Casablanca
    Check for loose connections, ensure proper power supply, and inspect the infrared components for any damag
