sm74 di issues need help
Discussion in '4-Color Offset Presses +' started by CajunCowboy, Jun 12, 2020.
  1. swilson513
    swilson513 Member
    Oct 2009
    80
    USA
    With or without air pressure
    Min value 25.0
    Average 25.0
    Max 25.0
    Only way to reset values is to unplug the transducer. is there away to check the SA2 module?
  2. Mathew
    Mathew Senior Member
    Apr 2010
    533
    Kolding-Denmark
    SAK2 is damaged unfortunately.
    There is no way to check SAK2 unless you mount it on another machine. But there is a risk of loosing data or transferring totaliser from one machine to another.
    It's possible to repair it, buy it takes time.
    Send a photo by email from top and back side of SAK2.
    Good luck,
  3. swilson513
    swilson513 Member
    Oct 2009
    80
    USA
    I checked the voltage at the transducer and it’s 27.6v it’s the same at the power strip across -8 & +8. I thought I had read that it should be 24v, could that voltage difference be the problem?
  4. Mathew
    Apr 2010
    533
    Kolding-Denmark
    That's fine.
  5. swilson513
    swilson513 Member
    Oct 2009
    80
    USA
    Okay we soldered in the potimeter. That did allow the the adjustment needed to get the press running. I did notice that adjusting the I4 values also was changing the I1 values.
    Tracking back through the schematics looks like those two are running back to the SFM board. Would that be the board with a problem?
