SM74-8color 2005 NTK board no supply
Discussion in 'Heidelberg Printing Presses' started by Linus, May 9, 2025 at 11:32 AM.
  1. Linus
    Linus Member
    Sep 2011
    59
    Portland
    Hi, the machine shows Fault Detected during operation message and Emergency button pressed sign without location. No display in Feeder or Delivery small display.
    INIT test show
    S-EAK 1 to 12 F3FF
    Dyn Test shows
    S=LA NTK FFFE
    S-EAK1 to 12 F3FF
    On panel board Second NTK board has Led off. Swapping NTK board, reasult is same. Second NTK board led off. So the board may not be problem. The input or output for the board may be problem.
    All circuit breaker are OK. Please suggest.
  2. Mathew
    Mathew Senior Member
    Apr 2010
    600
    Kolding-Denmark
    Most likely there is a short circuit somewhere in the machine. Start checking the dampening solution sensors on the units. The faulty ones become warm and even hot. The next can delivery pile height control sensor. Check the cable as it gets damages.
    Good luck
  3. Adil
    Adil Senior Member
    Nov 2021
    1,327
    Casablanca
    Check the grm power ??
