The S.E.K. unit in the Heidelberg electrical cabinet (l'armoire électrique) is a critical central control/power board. When there is an issue related to it, it can prevent the machine from initializing or operating completely.
Since your description is quite brief, could you provide a few more details so the community can help you troubleshoot?
Error Codes: Are there any specific error codes or initialization failure messages showing on your CP Tronic or press console?
LED Indicators: If you check the S.E.K. board inside the electrical cabinet while the power is on, are there any red LED lights illuminated, or are any expected green LEDs completely off?
Fuses: Have you checked the small fuses located directly on the S.E.K. board? A blown fuse on this board is a very common issue. (Make sure to test them with a multimeter).
Machine Symptoms: What exactly is the machine doing or failing to do? (e.g., dead console, main motor won't start, continuous beeping?)
If you can share a photo of the S.E.K. board's current LED status or provide the specific error code, it will be much easier to point you in the right direction!
