SM74/10P CP2000 problem
Discussion in 'Heidelberg Printing Presses' started by Rui Pereira, Nov 28, 2023.
  1. Rui Pereira
    Rui Pereira Member
    Nov 2023
    16
    Mozambique
    Hello. Im new on here. I need help on this problem on my machine.
    Doesnt pass from here, and the ink keyboard show that red X. Already switch the boards under the Key pad, and still remaing the problem.
    Any One hás seen this typevof error befor?
  2. Raf77
    Raf77 Senior Member
    Aug 2023
    199
    United Kingdom
    Have you tried to switch to second HDD?
  3. Rui Pereira
    Rui Pereira Member
    Nov 2023
    16
    Mozambique
    Already in use.
  4. Raf77
    Raf77 Senior Member
    Aug 2023
    199
    United Kingdom
    Have you sorted it out?
    If not, just try to turn machine off, then switch the pc off. (On the pc switch to 0) Then turn machine on and after that switch the pc on.
  5. Rui Pereira
    Rui Pereira Member
    Nov 2023
    16
    Mozambique
    Thats the first thing to do on Heidelberg machines...to clear the error....done it 5 times... already solved the problem...dust and humidity under the boards of the ink keyboard. Thanks anyway
  6. Raf77
    Raf77 Senior Member
    Aug 2023
    199
    United Kingdom
    Well, you didn't mentioned in your first posts what have you done apart of switching the boards
  7. Rui Pereira
    Rui Pereira Member
    Nov 2023
    16
    Mozambique
    Sorry... I change the position of the boards, and the error dint desapegar, so i unmount all the keyboards boards and clean ir all...and check for cables problems. After cleaning, and mount all boards, the error desapear. In 30 years working whit Heidelberg SM...this whas One of the most strange error that i have seen
