What you have in effect done is move your problem into the plate cylinder gap. Heres the thing about changing the oscillation.... The setting you have now, that seems to have resolved the issue you spoke of, is nothing more than a band aid fix, for what in my opinion is something else entirely. The oscillation setting you changed should be able to move freely 360 degrees in order to move your ink charge as needed, WITHOUT the toning issue you described before you made the adjustment. I think you should focus some effort on the true cause of the "tinting" of your plate, because I don't believe the previous oscillation setting was it. Id be focused on things like a calcium buildup in your rollers for that unit, which would make sense, seeing how black is usually run first down and picks up the bulk of the calcium leaching from the paper. If you know that unit to be completely free of calcium then the next thing id be looking at would be roller setting both ink and dampener, along with roller durometers. If you still have trouble then id experiment with different inks and or fountain solutions. The good news for you is this.... Seeing how your press format is small enough to rarely if ever, encounter 4 color images imposed one behind the other from gripper to tail, your likelyhood of having to move your oscillation is slim!!! Never needing to move the oscillation again leaves the true problem still un resolved. I think it will only be a matter of time before this issue rears its ugly head again, in either the same unit or in another. It would be great for you if I turned out to be wrong but if if I turned out to be right, then id say you need to get busy.
