Pretty sure the 52 is same as older models. With wheels in lowest position, set .3mm gap between adjusting screw and lever. After that, rotate feeder to be sure they arrive at roller at same time. Adjust either to make arrival same. Then, with paper slips in forwarding suckers, rotate press until slips fall. There should be 1.5mm gap between wheels and roller.
