SM102 (Beep sounds & Size Change)
Discussion in 'Heidelberg Printing Presses' started by micsabri, May 22, 2025.
  1. micsabri
    micsabri Member
    Sep 2021
    76
    Singapore
    Hi to all master. I am facing 2 problems on my SM102-5-P2+L (year 1996):-
    1) No beep sound before machine running. It supposed beep sound first before machine running for safety feature. (photo show the beep speaker)
    2) Can't get exact position on side lay. Once the operator set the size, it always auto change to exceeded size then the operator need to adjust back manually. I suspect 1 of the board having issue, anyone know which is the relevant board?
    Hope anyone can advice. Thanks.
  2. junker1984
    junker1984 Senior Member
    Jan 2010
    1,191
    US, Midwest
    Side lay potentiometer is failing, likely cause of positional error. Suggest you check voltage at alarm, obviously, if there’s voltage in bursts and no alarm, the alarm is bad. Never saw one fail, but it’s surely possible. You may also find that the triggering relay has a burned out coil. Don't have schematics, but you'll find it in the delivery LVT.
  3. Adil
    Adil Senior Member
    Nov 2021
    1,352
    Casablanca
    Regarding to your description Perhaps you need to put the zero position , do hou have this probleme on the other side or only one ??
  4. micsabri
    micsabri Member
    Sep 2021
    76
    Singapore
    Can I know how to reset into zero position?
  5. Adil
    Adil Senior Member
    Nov 2021
    1,352
    Casablanca
    There is a procedure for setting up the rectifiers pulling them to their position but to do it quickly try to put a sheet to print in the center of the margin table then launch the form automatically from the console it will certainly give an offset unplug the rectifier potentiometer and manually move the rectifier until it approaches the sheet by 5 mm then plug the potentiometer back in using the drive belt and that's it it's approximate
