SM102 2P Issue all dampening motor and slow down drum not function
Discussion in 'Heidelberg Printing Presses' started by maizal, Dec 11, 2024.
  1. maizal
    maizal New Member
    Dec 2024
    kuala lumpur
    Hi I am new; can your team give advise how to fix this problem
  2. junker1984
    junker1984 Senior Member
    Jan 2010
    1,134
    US, Midwest
    You must post pictures of service (diagnostic) screens.
  3. maizal
    maizal New Member
    Dec 2024
    kuala lumpur
  4. junker1984
    Jan 2010
    1,134
    US, Midwest
    Start with basics, turn off power and reseat all boards, with a focus on HAK and LTK, in main cabinet.
  5. maizal
    maizal New Member
    Dec 2024
    kuala lumpur
    thanks for your infomation, i will try n check.
  6. Adil
    Adil Senior Member
    Nov 2021
    1,287
    Casablanca
    Hi sit like junker told you , try to remove and push again the hak board and clean very well the plugs , also check the ntk power supply board if it s ok you can replace the ntk with similar one to be sure that s ok
  7. maizal
    maizal New Member
    Dec 2024
    kuala lumpur
    Hi Adil, thanks for your advise. i had try follow the prosedure and swap the HAK boards but still same. I check the slow down motor and found that 1 connector pin was problem. the connection was lost. repair the the connaection. Currently the faulty was solved. tq for advise
  8. Adil
    Adil Senior Member
    Nov 2021
    1,287
    Casablanca
    Good job .
