SM CO Error #15
Discussion in 'Heidelberg Printing Presses' started by Zeta, Apr 5, 2014.
  1. Zeta
    Zeta Member
    Mar 2014
    6
    Egypt
    I have SM 52 CP TRONIC MODULAR, 5 unit + 1 coating
    Pathetic machine doesn't run,
    The are two red mulfunction! Sek error and main cabint
    And three blue mulfunction? Check dryer, check open guard, ...
    Can any one help me to understand what is mean by blue malfunction while when I open the guard transfer to red error with the same name!
    And for the SEK error? How can I found it ?
    And it have another problem the main delivery pile not up but can be Down? I changed the flat data cable in SLM1 and SLM2 and it up and down from feeder key!! But the problem transfer to the up of feeder pile?
    Can any one help me for that?
  2. exheidmech
    exheidmech Senior Member
    May 2009
    674
    USA
    Very likely your problem with SEK and blue malfunction is the guards on the drive side delivery. Make sure they are closed properly and make sure that the magnetic switch on door is positioned properly with the magnetic switch it matches with when door is closed. This is quite common on older SM52 due to the fact that these doors will sag over time making a misallignment between both halves of switches.
    Delivery problem is most likely the eye or sensor in delivery which limits pile upward movement. Make sure this eye is clean. A dirty eye will not allow pile to move upward. I cant remember if this eye is located on Drive side or Operator side but it is imbedded in the side frame slightly and is glass. Just wipe it off with a dry cloth.
  3. Zeta
    Zeta Member
    Mar 2014
    6
    Egypt
    Hi exheidmech,
    Thanks for your reply, I checked the door and it closed well.. And when I opened it the fault become red not blue and it appear on Cp 2000 that it is open... But the strange thing ... It is closed and it show on cp 2000 by blue? What is the different between blue and red fault?
    And for the delivery pile I checked the eye, and it is ok... And measure it and also it is ok ... there is any thing else to check?
    Thanks for your support...
  4. Waqas_zahid
    Waqas_zahid Senior Member
    May 2011
    223
    Pakistan
    Does the SEK error appear at boot up and go away when you acknowledge it? There are two connections going out of every safety switch, one goes to EAK and other to SEK, when the safety indicates a blue malfunction that means signal going to the SEK is disturbed where as it is displayed in red when the signal to the EAK is disturbed. What is keeping you from running the machine? can you post a picture of the errors? May be you can go into diagnosis to check?
    About the delivery sensor can you check if it giving any ouput? I would recommend to trace the wire going to the LVT box remove it's output pin and then check the pile may be the sensor is already shorted out.
  5. Zeta
    Zeta Member
    Mar 2014
    6
    Egypt
    image.jpg Thanks all the error solved.... There was micros witch bad contact....
    And now there is no any error....
    But when put machine on run it run 2 to 10 second and stop without show any red error....
    And there is one yellow one... Double sheet detector of pulling device...is this one make this error or there is hidden one?
  6. Waqas_zahid
    May 2011
    223
    Pakistan
    apologies for the late response, great to know you traced the problem and solved it, what about the delivery pile? has that been resolved as well? I am not sure about the double sheet detector at the sidelay, normally if its malfunctioning you can turn it off since there is already another one ultrasonic double sheet detector just at the infeed, if you are sure there are no double sheets then you can try turning off this sensor and try to run the machine, be very careful when doing so and be sure the double sheet at the infeed is working.
  7. smtint3
    smtint3 Member
    Nov 2014
    5
    Karachi,pakistan
    Error # 15> sek heidelberg 102/1990
    Dear SIR/MADAM,
    I have a HDL 102 speed master running last week perfectly, all of a sudden every thing stopped, the error its showing is # 15 SEK,
    the images of the display are attached, please help with this issue asap.
  8. aqazi81
    aqazi81 Senior Member
    Oct 2009
    827
    KARACHI PAKISTAN
    Dear smtint3,
    I have already suggested the solution to your electrician.
  9. MRFIXIT
    MRFIXIT Senior Member
    Aug 2014
    43
    U.K.
    HELLO smtint3..HAVE YOU RESOLVED THE SEK ERROR? THIS IS A PROBLEM IN THE GUARDS/SAFETY SWITCHES..I HAVE HAD A SM72 CPTRONIC PRESS WITH A SUDDEN STOP PROBLEM LINKED TO MICROSWITCHES...THE CULPRIT WAS THE SWITCHES ON THE INKING FORME ROLLERS WHICH WERE BOUNCING AND TRIGGERING THE SWITCH FOR THE ROLLER CUP OPEN..IF ITS NOT THIS IT COULD BE ONE OF MANY GUARD SWITCHES..THANKS..
