SM 74 No Pressure
Discussion in 'Heidelberg Printing Presses' started by alphapressfl, Oct 11, 2024.
  1. alphapressfl
    alphapressfl Member
    Nov 2016
    43
    orlando, florida
    hello. We have a SM 74. Machine was running fine and we had a power surge. We restarted the machine and it will not print.
    Gives us error about not enough pressure. We checked the lines and we have 140 psi coming into the machine.
    Could it be electrical? Any ideas?
  2. Beguin
    Beguin Senior Member
    Jan 2020
    395
    Côté d'ivoire
    Hello dear sir, can you show us the error that the machine indicates on the screen, thank you.
  3. junker1984
    junker1984 Senior Member
    Jan 2010
    1,158
    US, Midwest
    140 psi? The pneumatic components are not rated for that. Typical regulator setting is 7 bar (98 psi). Is it possible the pressure sensor has been damaged by excess air pressure?
    asem alsafady likes this.
  4. alibryan
    alibryan Senior Member
    May 2014
    240
    States
    “hello. We have a SM 74. Machine was running fine and we had a power surge. We restarted the machine and it will not print. Could it be electrical? Any ideas?”
    Electrical issues after a power surge is a good guess, but who knows for sure? You say you restarted the machine and it will not print? Does that mean you turned the power switch off and on, and then pressed the production button? Or what did you actually do, exactly? You have to be a little more specific.
  5. Raf77
    Raf77 Senior Member
    Aug 2023
    258
    United Kingdom
    Insufficient pressure?
    There may be a fuse tripped in the air cabinet
