SM 74 Daystar 2000 error 1603 & 1713
Discussion in 'Heidelberg Printing Presses' started by Prodip, Nov 18, 2023.
  1. Prodip
    Prodip Member
    Nov 2023
    5
    Uk
    Dear sir,
    Please help,
    The IR light turns off after a while after the 1713 and 1603 errors come to the dryer. If I turn the IR off and on, then the IR light turns on for a while.than Again off IR light.
    Plesse help
  2. Beguin
    Beguin Senior Member
    Jan 2020
    395
    Côté d'ivoire
    hi dear sir please check if the water pressure is good or bad.
    Faysal87 likes this.
  3. Prodip
    Prodip Member
    Nov 2023
    5
    Uk
    Dear sir,
    Please see the IR water level meter.
  4. Raf77
    Raf77 Senior Member
    Aug 2023
    267
    United Kingdom
    You need to top up your water pal
  5. CHOCK
    3,092
    1703 : Dry operating at maximum IR level: check control parameters
    1603: Dryer operating at maximum heating output : check maximum level of parameters
  6. Prodip
    Prodip Member
    Nov 2023
    5
    Uk
    Sorry sir,
    I am not understand, could you please help me for understand.how i am check maximum level of perameters.
    Please.
    Thank you sir
  7. CHOCK
    3,092
    Hi sir;
    Any error listed above, the parameters you must compare according with the instruction manual of your machine!!
    Very Simple.
