SM 74 air pressure error
Discussion in 'Heidelberg Printing Presses' started by Waldos1, Nov 28, 2018.
  1. Waldos1
    Waldos1 Member
    Jan 2017
    15
    Memphis,Tn
    Getting a red light showing insufficient pressure. Compressor is ok. For some reason the sensor is not allowing the valve to open.
  2. junker1984
    junker1984 Senior Member
    Jan 2010
    1,035
    US, Midwest
    Could be your I/O (EAK) board. In which case, there wouldn’t be 24V at the plug. Check w/ meter. I’ll f 24v is present, you’d have a failed or fouled pressure release valve.
  3. Waldos1
    Waldos1 Member
    Jan 2017
    15
    Memphis,Tn
    Ok thanks. I will check that out. For now we have installed a potentiometer to bypass the sensor.
  4. n70_music
    n70_music New Member
    Aug 2019
    Viet Nam
    Hi sir, sir can share guide bypass sensor,
  5. Raf77
    Raf77 Senior Member
    Aug 2023
    226
    United Kingdom
    Make sure you don't have water in the airline system.
    And there are 2 or 3 fuses in the air cabinet (acces from the step platform) make sure any of them isn't tripped.
  6. Jack liston
    Jack liston Senior Member
    Sep 2019
    271
    Connecticut
    Check for leaking hose
  7. asem alsafady
    asem alsafady Senior Member
    Mar 2016
    180
    Amman Jordan
    Dear Sir,
    If your compressor is OK.
    Close or bend the main hose after the regulator (usually under the feeder),
    Watch the regulator's clock, if it's going down, you have to check before the regulator. If it's going up, then you have to check for a leak after the regulator, you can close the hose which feeds all the machine except the feeder, search for leak in the feeder. Then continue to check (at the same way) if there are any leakages in the units one by one until you find the exact leakages positions and fix them.
