SM 52_2 colour feeder clutch not working
Discussion in 'Heidelberg Printing Presses' started by ADK, Mar 26, 2023.
  1. ADK
    ADK Member
    Mar 2023
    24
    United Arab Emirates
    Sir what is the function of this board please explain. IMG_20230401_165242.jpg
  2. CHOCK
    2,927
    What did the happen??
    Measure???
    Blessings
  3. CHOCK
    2,927
    Interface distributor module.
    Blessings
  4. ADK
    ADK Member
    Mar 2023
    24
    Hi sir thank you for supporting I find the fault. The problem in the communication. The wire is cut. Now ok. Thank you so much.
  5. CHOCK
    2,927
    Ok, am happy that you did a great work.
    I did instruct you, to use the:
    " common sense", the most invaluable tool x troubleshooting, indicating you, to look carefully, inspect every thing, and test the continuity.
    Blessings.
  6. ADK
    ADK Member
    Mar 2023
    24
    Thanks you so much
  7. foliart.net
    foliart.net Member
    Mar 2010
    9
    Bulgaria
    Dear Sir,
    Can You help me? I am installing one Sm 72 2 HP year 2005 now in my company and I have problem with Feeder compressor feeder clutch they are always ON . I found that the VSM2 board is burned and now I am waithing new one.
    But I also can not move the feeder and delivery table. On the computer, I don't have any errors for them.
    Only error for the grease monitoring system . I put grease in the tank but the problem remains and i find out that there is leakage one broken pipe under the feeding table. I will fix that maybe after two days but my question is is this VSM2 board has anything in common with the problem on the feeding table a delivery table .
  8. CHOCK
    2,927
    Hi sir :
    1)You must test the NTK Regulated Power Supply FIRST !! in tolerance 0.7% up or down, otherwise, you must the same problem, repair or replace it.
    2) the VSM2 module amplifier, has NOT Relation with the Feeder and Delivery Table . Repair the Leak very well.
    3) i strong recommend you that since machine is OLDER, review carefully the REAR PANEL CONTROL: Dry + Colder joint Solder !!! and Reheating, after you saw that problem is NOT Fix IT !
    Let me know.
  9. foliart.net
    foliart.net Member
    Mar 2010
    9
    Bulgaria
    Hi Can you send me your whats up number. My is 00359899863051
    Best Regards
    Krasimir Georgiev
  10. Joe Burger
    Joe Burger Member
    May 2023
    15
    Germany
    hello, I would say that you forget searching for 24Volt Problem, then just cleaning the clutch with a solvent, then try it again engaging and starting feeder.
    Most of the problem at the clutch are coming from dirty stuff inside.
  11. youngBOSS
    youngBOSS Member
    Jun 2017
    38
    Accra
    If your problem still exists, I would like to add this. Ensure that the delivery table limit switches are working correctly, especially the table down limit switch. Check 12S63 on operator side of delivery and +24v dc present from this switch at 1.15EVM3. 63
  12. ADK
    ADK Member
    Mar 2023
    24
    Hi sir we have problem in polar 98 machine the error showing knife after running too large please help me
  13. CHOCK
    2,927
    Hi Sir:
    What error do you have?
    And model of polar? 78, 92, E,ED,XT, CE, EL,???
    However check:1) regulated power Supply arriving to the both Cut Button +24 VDC, look defective Cut Button+ loose wires + connectors corroded
    2) Safety Bolt if there+42Vdc, look loose wires, dirty, corroded connectors, or safety Bolt, lack of LUBE
    3) limit switch or sensor in gear plastic can, dirty, defective, or need adjustment., Look loose wires, corroded connectors, or defective sensor or limit switch defective.
  14. ADK
    ADK Member
    Mar 2023
    24
  15. ADK
    ADK Member
    Mar 2023
    24
    Thank you sir for your reply sir when we start cutting after every cuts the error showing. I don't know what is the problem.
  16. CHOCK
    2,927
    Inspect: clutch: oil, brake air gap, springs.
    Check magnetic clutch, x air gap, with spring
    Inspect mechanical gear play
    Cutting circuit transformer SKU
    Replace spring x brakedisk( gearbox).
    Blessings
    ADK likes this.
  17. ADK
    ADK Member
    Mar 2023
    24
  18. ADK
    ADK Member
    Mar 2023
    24
    Hi sir we have problem in man roland Tyepe 300 machine error code 0910004 please help me
  19. CHOCK
    2,927
    Dear Sir :
    Please reset the CPU in the MOBO ( MAIN BOARD) , attached is there my own schematic, how to do it.
  20. ADK
    ADK Member
    Mar 2023
    24
    OK thanks you sir
