SM 52 Stuck at CP Tronic
Discussion in 'Heidelberg Printing Presses' started by setyawanteknik, Feb 7, 2024.
  1. setyawanteknik
    setyawanteknik Member
    Jan 2024
    8
    indonesia
    Hi, i have problem with SM52, the ZID stuck at CP Tronics logo,both the MID stuck at heidelberg logo,i have measure the NT power supply the 5v output are 5,13v and the 24v output are 23,56v. When i turn off the machine and keep it off overnight the mid are normal and the button working both in the delivery and the feeder but the ZID stuck,after the machine restart both the ZID and MID are stuck, any advice are greatly appreciate,thank you
  2. Beguin
    Beguin Senior Member
    Jan 2020
    348
    Côté d'ivoire
    hi dear sir, please check the SVM card.
  3. setyawanteknik
    Jan 2024
    8
    indonesia
    hi Beguin, i was able to enter the init test after swap between the REK1 and REK2 (RGP2) board, the init test blink 0000 for REK1 and the dyn test show 7ffc for REK1, i swap the epm/eeprom between REK1 and REK2 board and still the same issue with REK1 init test and dyn test
  4. setyawanteknik
    Jan 2024
    8
    indonesia
    The lcd screen and buttons in the both MID seem work normal
  5. Mathew
    Mathew Senior Member
    Apr 2010
    529
    Kolding-Denmark
    I assume REK1 is defect. Can you check if the softare of both REKs are shown on CPTronic?
  6. setyawanteknik
    Jan 2024
    8
    indonesia
    Yes before i swap REK1 and REK2 it stuck on CPTronic.When i swap the EPM it still init 0000 at REK1 so i assume the both EPM are fine, i read some threads here that need replace the bus arbiter and/or parallel interface IC, @Mathew do you have experience repair this board?
  7. Mathew
    Apr 2010
    529
    Kolding-Denmark
    Are both REKs recognized by CPTronic? Can you send a photo from software version menu on CPTronic?
  8. setyawanteknik
    Jan 2024
    8
    indonesia
    when i swap REK2 to REK1 it can enter init test, otherwise it stuck on logo, im sorry it day off today i am unable to check the software version
  9. Mathew
    Apr 2010
    529
    Kolding-Denmark
    I know, check it in the condition that you can look through CPTronic menus.
  10. setyawanteknik
    Jan 2024
    8
    indonesia
    here are the machine nameplate
  11. setyawanteknik
    Jan 2024
    8
    indonesia
    how to check?
  12. Mathew
    Apr 2010
    529
    Kolding-Denmark
    Service---> Service 2----> The first button from left side
  13. setyawanteknik
    Jan 2024
    8
    indonesia
    oh do you mean check the software version, i only have the fault codes for compact version but not the modular
  14. Mathew
    Apr 2010
    529
    Kolding-Denmark
    Please do whatever is told you.
  15. Adil
    Adil Senior Member
    Nov 2021
    810
    Casablanca
    If all power supply 24 v and 5v are good you need now to check grm perhaps some power supply is missing .
