SM 52 Impression off problem
Discussion in 'Heidelberg Printing Presses' started by old school 52, Nov 17, 2016.
  1. old school 52
    old school 52 Member
    Apr 2014
    79
    United States
    Good Morning,
    Our SM 52 ( 1st unit) will not come off impression in two steps. Goes on fine but coming off it skips the first step then everything comes off in one step. If the feeder trips it sometime sticks releasing air until it trips the press. Removed and cleaned the pneumatic valves top and bottom of piston valve. When running I have a faint air leak in bottom valve coming from sound reducer port.
    Any suggestions?
  2. exheidmech
    exheidmech Senior Member
    May 2009
    674
    USA
    Try swapping the entire pneumatic cylinder with the one on the second unit. Most likely a bad cylinder. Impression on/off is software controlled on SM52. Any issues with it coming on or off impression are most likely the cylinder itself. If you have the old style than possibly the valves on the cylinders could be the issue. New style is a round cylinder old style is square.
  3. old school 52
    Apr 2014
    79
    United States
    Thanks for the reply. This cylinder is square. We have replaced one of the valves (bottom) after talking to Heidelberg. Nothing changed. Then swapped it from bottom to top, nothing changed. Is it possible to remove the cylinder and clean it. Seems to me it could be just gummed up. We recently had a compressor full of water which entered the lines. If we do swap the valves between units will the stroke adjustment be the same or need adjusting? Really not comfortable with that.
    Thanks in advance exheidmech
  4. aqazi81
    aqazi81 Senior Member
    Oct 2009
    827
    KARACHI PAKISTAN
    Yes, the stroke adjustment is same.
  5. old school 52
    Apr 2014
    79
    United States
    Thank You
