SM 52 cylinder jacket replacement
Kartal55
2016
55
Australia
First time we'll be doing this, any instructions or tips would appreciate it
good evening dear sir, please refer to the instruction manuals of the machine. thank you very much
  • If i had the instruction manual i would not have started this thread... we don't have the instructions!
    hello dear sir, don't take it the wrong way. it's not something difficult but someone has to do it in front of you so that you can do it too because there are springs that catch the blanket and if you If you can't, you risk breaking them. I can explain it to you. It doesn't bother me, but you still have to understand the explanation. It's something difficult, but the explanation will be long and perhaps misunderstood. thank you very much
    You should have the jacket bar somewhere it's used to keep jacket tight as you inch on to cylinder
    Suggest you not use bar to keep jacket down while inching machine. Its purpose is to push lead/tail edges down while clamping. Very old versions of 40” jacket jigs had a moveable plastic insert that could be used as Jack mentioned.
    Thanx guys...i must have changed around at least a dozen jackets on GTO's during my time but never on a speedie! Just reading through some of the advice of my 'peers' here... tells me it's kinda tricky!
    Occupational hazard caused by those dang 'perforation wheels '. ...
    Hi sir
    normally there is a plate retaining bar when mounting but you can successfully mount without using it.
    start by entering the 15 mm fold in the grip of the clamps tighten the btr screws with the cipan 5 after turning step by step by keeping the plate on the cylinder and then enter the 8 mm fold in the stretching bar and tighten the hexagon head screws with spanner 13 at the end tighten the plate with the hexagon head screws in the same bar
    Good luck
    Hi sir
    Good luck
    Make sure you have all the necessary tools and a clean workspace.
    When you’re ready, carefully remove the old jacket and pay close attention to how it’s installed.
  • If he do very well the procedure i gived to him , he will not be puzzled , it simple to do you must only do the right things and procedure
