I have the problem for sm 52 perfector synchronization Monitoring not acknowledgment in PU. Évery Time on the machine display show the error for reversing Durm Lock.
hi sir if it;s the same machine and if you have correctly set up all the devices on the front side. then, To acknowledge the disturbance, you must: - press the Stop push-button on the set command and hold the button depressed, - press the Acknowledge fault key interaction control in the Fault menu, the key goes out, - release the Stop push-button on the control station Remote control.
please if it does not work go into the trouble menu and send me a photo. to tell you where you can go to find the exact error code because this sign of synchronization that you showed me in the photo means a lot of things . follow me step by step
Yes sir ,pess it on the set command and hold the button depressed then press the Acknowledge fault key interaction control in the Fault menu,the key goes out, and release again the Stop push-button on the control station Remote control
