Sm 52.2, dampened problems.
Discussion in 'Heidelberg Printing Presses' started by old school 52, Apr 3, 2024.
  1. old school 52
    old school 52 Member
    Apr 2014
    79
    United States
    New ink and dampener rollers 6 mths ago. Dampening problems ever since. Also company changed to Kodak on press developing plates and different ink supplier at the same time. Using S-3001 fount solution from bottcher. Only thing that hasn't changed. Thinking of changing to a tower product. Problem, just can't maintain good dampener settings.
    Any suggestions?
  2. Raf77
    Raf77 Senior Member
    Aug 2023
    231
    United Kingdom
    Yes. Rollers settings
  3. old school 52
    Apr 2014
    79
    United States
    ...yes I get that. If it was something mechanical it wouldn't be same problems in both units, right?If I had a dollar for everything I reset I could retire.
  4. old school 52
    Apr 2014
    79
    United States
    The only thing shady about settings is the form to Chrome setting, having a variable strip because of rollback book says.
  5. silviumihaila2002
    silviumihaila2002 New Member
    Feb 2009
    Bucharest
    First check dampening solution, pH aditive and IPA, alcool, if this is OK, check rollers setings.
  6. alibryan
    alibryan Senior Member
    May 2014
    223
    Somewhere
    What are the dampening problems that you speak of?
    Are the Kodak plates Sonora X?
    How are you rolling the plates up?
    Is the Bottcher 3001 a 1-step fount?
    What ink are you using?
    All roller settings are correct, including the Z roller?
    Have you tried disengaging the Z roller, and running segregated?
  7. old school 52
    Apr 2014
    79
    United States
    I have water swings from one side to another after starting run, maybe 100 to 150 sheets in. Which is what book describes about chrome roller not being centered on meter roller.
    S3002 is a two step. Running 3 oz per gal at 6 % alcohol. Water reads 200/250 depending on day, 420 to 460 typically at 3 oz per gallon. Rolling plates up on scrap sheets as instructed. Sometimes clean in 4 or 5 sheets other times much more difficult.
    Checked bottcher site S3002 is not even listed??
  8. Jack liston
    Jack liston Senior Member
    Sep 2019
    278
    Connecticut
    The owner's of your company are not doing anything to help.when they changed plates .ink and solution all the vendors should have been in the pressroom at same time to get everything dialed in.been through this too many times.you should throw it back in their lap hopefully you can sort it out
  9. Raf77
    Raf77 Senior Member
    Aug 2023
    231
    United Kingdom
    Are there more presses in the company? Does it happen on all of them or just yours?
    While they changed plates to processless, didn't they change your pre damp settings to better develop the plates? Maybe there's too many revs on start and then you have too much water on first 100 - 150 sheets?
    If that's ok, and if you still have some of your old fountain solution, just drop this one and put old one in. Then you'll se if it's solution or not. I'd say that would be the rollers issue (hardness, settings, pre damp)
  10. Jack liston
    Sep 2019
    278
    Connecticut
    The water form stripe May be place to start set at 5mm and go from there if you have an old plate try it .then process of elimination.good luck
