According with the Error code shown: you have over current in SBM2
1) Please review if the Input control voltages are NOT fluctuatin over 10% Higher or down, call the supply company if this the problem
2) Test the Belt of Main Motor, if there are loose or very Tight??
3) Touch with your hand if the Motor coming Heat.
4) See for loose wires in the terminals Main Motor, or connector, or dirty, or corroded, or oxide, and tight and clean very well.
5) If the problem persist: Time of Maintenance Main Motor. Every electrical motor the time for doing maintenance is 8 months aprox. Lube the bearing or replace, clean it, and lube completely.
