Side guide do not work correctly - sm102
Andrei83
2017
61
Russia
Roller do not touch registration plate. But if one move side guide via cp2000 to plus/minus 1 mm, roller will correctly touch plate again. Can anyone tell me why?
hi dear sir what roll are you talking about? and what is the real concern, if possible a pictures to support it thank you and God bless us
  • Side guide do not work correctly - sm102
    Wear on the drive thread possibly ?
    The roller does not touch the pulling bar.
    Dear Andrei
    As I understand, I think that the guide rail under the side lay roller is worn, or some tooth at the rail are damaged.
  • The pulling bar is normal and not worn out, it moves normally. Just the roller does not touch it about 4 mm.
    Fountain solution may have leaked into pull rail casing, rust damage to waffle (linear) bearing support. Brass guide casing may be worn, loose on shaft.
