Shinohara 66iv problem
Discussion in '4-Color Offset Presses +' started by Offset doctor, Sep 5, 2022.
Tags:
  1. Offset doctor
    Offset doctor Member
    Jul 2021
    7
    India
    I'm facing problem in shinohara 66iv 2000 the problem is the communication between CPC and ink key are lost I think because other than ink motor everything is working
    all 4unit ink motor has error has any body face the same thing?
  2. CHOCK
    3,051
    1) measure the regulated power supply in tolerance 0.7% up or down.
    2) look for loose connector, or loose cable.
    3) test the ribbon cables, or flat cables.
    4) clean the edge connector, most of 70% faulty in electronic is to due this, clean very carefully with the electronic spray.
    Offset doctor likes this.
  3. Offset doctor
    Jul 2021
    7
    India
    Hello sir thanks for your help hope you are doing while
    I need your help one more time
    Am working on shinohara 66iv straight machine year 2002 we lost display program that file format is onw can you help me
  4. CHOCK
    3,051
    Thank you sir by his words.
    However I do not have way for software, you must contact to the factory.
    Sorry for this inconvenience.
  5. ASHISH TELANG
    ASHISH TELANG Member
    Dec 2014
    17
    Pune
    Pls whats app me details on 8788838615
  6. CHOCK
    3,051
    Which country is your
    Blessings
