SEK error flashing in main cabinet
Discussion in 'Heidelberg Printing Presses' started by Oliver Israel Jr, Nov 27, 2021.
  1. Oliver Israel Jr
    Oliver Israel Jr Member
    Nov 2021
    11
    St Johns
    Hi,
    Did safety check by opening and closing all switches and guards. All flashing icons cleared on the ZID of SM52-53 1998 CPtronic. Even after clearing the safety check, I still get SEK flashing on top of cabinet. Attached is the SEK. Any other checks I need to look? Please advise. Thank you.
  2. junker1984
    junker1984 Senior Member
    Jan 2010
    1,036
    US, Midwest
    That screen shot 2ill not help in troubleshooting your issue. Must originate at INIT Test or DYN Test.
  3. Oliver Israel Jr
    Nov 2021
    11
    St Johns
    There's no Init or Dyn test error showing at t=0. No error showing blinking guards or switches also.
  4. junker1984
    Jan 2010
    1,036
    US, Midwest
    Same for t1-t5?
  5. Oliver Israel Jr
    Nov 2021
    11
    St Johns
    Not even at t-1 to t-5 history. Thanks
  6. Thirumalaikumar
    Thirumalaikumar Member
    Nov 2021
    16
    India
    there is relay symbol in SERVICE menu(spanner button),press that and find in the display somewhere----s=some number &E=some number ....
    in that what are the numbers it showing ?
  7. Beguin
    Beguin Senior Member
    Jan 2020
    348
    Côté d'ivoire
    Hello sir, could we show us what the desk displays compared to the SEK and the reception screen and that of the ladder (picture) thank you.
  8. Thirumalaikumar
    Nov 2021
    16
    India
    hello oliver ,
    any update
  9. Oliver Israel Jr
    Nov 2021
    11
    St Johns
    Hi TH,
    There's no S and E number for CPtronic machines. The S and E number is for CP2000. The relay symbol you're referring to is a safety check wherein if selected, all safety buttons and guards switches will start flashing. After clearing by opening and closing the switches and buttons, all the flashing buttons will disappear. That's what is happening to this machine, It pass the safety check.
  10. Oliver Israel Jr
    Nov 2021
    11
    St Johns
    I will post some pictures when I come in on Monday.
  11. wunmi-50
    wunmi-50 Senior Member
    Jan 2013
    90
    Lagos,Nigeria,Africa.
    Hi Oliver.
    From the SEK screen you posted, it is clear you have safety issues in the Feeder and on the Cptronic console. So as soon as you post more pictures as you proposed, it may be clearer where exactly the problem is. Looking forward.
  12. Oliver Israel Jr
    Nov 2021
    11
    St Johns
    Picture of SEK error
  13. Oliver Israel Jr
    Nov 2021
    11
    St Johns
    Picture at the start of safety check. Notice all buttons are flashing
  14. Oliver Israel Jr
    Nov 2021
    11
    St Johns
    After safety check, all are cleared.
  15. Oliver Israel Jr
    Nov 2021
    11
    St Johns
    SEK still flashing beside the cabinet until now when after clearing all buttons, switches and guards.
  16. Beguin
    Jan 2020
    348
    Côté d'ivoire
    hi dear sir, please can i have what the margin screen and the reception screen display? thanks very much!
    Picture.
  17. ashok kumar
    ashok kumar Senior Member
    Nov 2017
    224
    india
    As per pix give in start
    There in safety (xes pin 3) is one it should be zero.
    Check as per drawing which switch is for the same ( swith no point is closed due to which fem xes pin 3 is one ) for purpose remove wire from pin xes 3
    Then sek error will off
  18. Oliver Israel Jr
    Nov 2021
    11
    St Johns
    Hi Ashok, Thanks for your reply. Sorry I attached the wrong SEK picture. You're correct though that it should be zero. Unfortunately, it was zero initially when I have the SEK error. This is the SEK picture that I should have posted.
  19. ashok kumar
    Nov 2017
    224
    india
    Hi
    Let the display remain sek page and press total stop(estop) from units and check is it getting change or not .
    Or check sek card on other machine
  20. wunmi-50
    Jan 2013
    90
    Hi,
    You initially have two safety issues as per your first and posted SEK display, one in the feeder, which you somehow have now eliminated. Kindly avail the forum on how you achieved this.
    The remaining Error is related to your Central Control Console. So you have to check the safety related switches on the console. For example, the Emergency stop button there, and possibly other safety relevant switches like the inch selection, auxillary stop button etc.
    Can we safely assume your console is equipped with an EAM board? It may be helpful if you can post external and internal pictures of your Central Control console to show it's make-up.
    That's all for now.
    Regards.
