Scorotrons
Discussion in 'HP Indigo Digital Presses' started by indigo2015, May 14, 2019.
  1. indigo2015
    indigo2015 Member
    Aug 2015
    35
    rome (Italy)
    Hello all,
    Does anybody knows what causes scorotrons problems? Is there any internal part that must be cleaned very well or some part need to be replace?
    Thanks in advance.
  2. FFR428
    FFR428 Senior Member
    Feb 2008
    425
    CT
    I've had to spread the pins on the nop side emd a bit sometimes to make good connection. Had to replace the end cap once also. Other than the corona wire, spool, plastic strip and grids they are pretty durable. What issues are you having? Normally the grids get cleaned and inside of the housing when you change the corona wire. I use IPA and windex and clean with a lint free wipe.
  3. indigo2015
    indigo2015 Member
    Aug 2015
    35
    rome (Italy)
    Hi, mainly I can here electric discharges notice and the I have an error SMS. Don't want to replace all the end cap or all the rear cap... or all scorotron.. just would like to know where is the problem and replace or clean that part.
    Thanks for your answer.
  4. indigo2015
    indigo2015 Member
    Aug 2015
    35
    rome (Italy)
    * hear electric discharges noise... write better.
