Schneider Senator 92 error code
Discussion in 'Cutters and Trimmers' started by Martin Zak, Sep 11, 2023.
  1. Martin Zak
    Martin Zak New Member
    Sep 2023
    Prague
    Hello, does anyone know what these error codes mean?
    SSR-1 Error: 0A Status:95
    SSR-2 Error: 74 Status: BA
    The cutter just lights up and says an error.
    Thanks Martin
  2. CHOCK
    2,745
    Test the slow
    blow fuse from F01-F11, and then look if the Cut microprocessor is coming +5 Vdc in tolerance 0.7% up or down.
    Otherwise repair or replace it.
    Of course clean the Edge conector from CPU, with erase pencial, and then spray contacts cleaner.
    Clean the pins of IC from CPU bother, from oxide, with electronic cleaner very well!
    Look, for Dry + Colder solder joint in the PCB TOO!!
  3. adnan azzam
    adnan azzam Member
    Jun 2018
    19
    Damascus
    Hi Mr Martin
    Please can you send a photo of the screen with the error message
    Best regards
    Adnan
  4. Martin Zak
    Sep 2023
    Prague
  5. Martin Zak
    Sep 2023
    Prague
    IMG_4231.jpeg IMG_4232.jpeg IMG_4235.jpeg IMG_4238.jpeg IMG_4237.jpeg IMG_4231.jpeg
    The fuses are ok.
