Sakurai Oliver 466SD can load the processor
rudysbp
2019
10
indonedia
Hello friend
I hv problem with sakurai oliver 466sd. The machine can't run.. And inthe console button lock is always turn on..
Anyone can help me.. Hiw can i fixed it
Tq verymuch
Hi sir;
Normally test the power supply from Vdc, must be in range of 0.7% up or down. otherwise, the console will NOT work.
However if the voltages are o.k please do this;
1) Perform a visual inspection : look for loose and broken wires, improperly seated connectors, loose or broken wires
Dust + dirt + tear +wear
Edge connectors are a common souorce of problems. Power down the system and remove the PC boards. Examine the edge connector
for contamination and clean with contacts cleaner contacts. Reseat any loose components such as scoketed ICs) . Reseat the
boards and power up.
3) Power supply checks:
Check the power supply for missing voltages and voltages out of spec. A digital multimieter DMM can be necessary, as
voltage specifications are quite tight: logic supplies for example: must be within + 5% percent of 5Vdc. All the
4) Board swapping:
Board swapping involves the substitutiono of a known godd board for a suspect one.
Blessing
  • Same problem I'm also face in Sakurai Oliver 480 SD. PLc Comm1 communications errors, wait SCC controller up and run.
    Give me solution please
