Sakurai Oliver 272EP2
Kelvin FP
2024
KZN - South Africa
My damper & chrome roller is inking up. My damper roller doesn't have a consistent speed, it slows down almost to a haul and speeds up
Not liking that plastic gear may be worn-out.make sure dampening roller is correct stripe to chrome and plate
  • Check that plastic gear if it is not spinning on the shaft.
    Set the rollers correctly and desensirize the chrome roller
    Adjustment parallel the roller with a Feeler to both size, and clean very well, look carefully the teeth of gears, are o.k , other wise, you must replace, and see if the ball bearing are o.k, possible damage, time of replace ir !!
    Friends! after battery failure ink volume gone mad up to 725% and can not be changed.
    Any idea? Please help!((
