Ryobi 924 Plate change
Discussion in 'Ryobi Printing Presses' started by Chris660, Jan 30, 2024.
  1. Chris660
    Chris660 Member
    Sep 2023
    8
    South Africa, Durban
    Afternoon guys, Our Ryobi 924 is giving an issue on the last unit. It does not complete the plate change cycle, although the plate is in, the green indicator light does not come on, signaling that the plate is changed. Any idea what could cause this?
  2. juanjo
    juanjo Member
    Jan 2013
    16
    SPAIN-MADRID
    Hello, good morning, it is possible that the cell on the motor side in the plate cylinder gear is not correctly detected. This fault can be removed by entering a code in the machine's software.
  3. Sandman
    Sandman Member
    Jan 2012
    17
    Norway
    Have you tried turning up the airpressur?
  4. fahrifinoza
    fahrifinoza Member
    Aug 2015
    30
    jakarta
    If plate already in and fix mounted well, maybe problem at quick tension valve sensor
