Ryobi 524HE error E-914
Discussion in 'Ryobi Printing Presses' started by jham, Jun 25, 2019.
  1. jham
    jham New Member
    Aug 2018
    UK
    Hi, does anyone know what is causing the error E-914 to come up on our Ryobi 524HE.
    When the error comes up the press stops.
  2. Mitrache Mari0
    Mitrache Mari0 New Member
    Nov 2023
    Bucharest
    Hi, did you solve this problem ? I recive the same error code....from what is it ?
  3. fahrifinoza
    fahrifinoza Member
    Aug 2015
    30
    jakarta
    E-914
    Maybe plate holding roller problem
  4. fahrifinoza
    fahrifinoza Member
    Aug 2015
    30
    jakarta
    Maybe switch always on
  5. fahrifinoza
    fahrifinoza Member
    Aug 2015
    30
    jakarta
    1st unit
  6. Mitrache Mari0
    Nov 2023
    Bucharest
    Hi, thank you for answer...but what and where... is the plate holding roller ?
  7. fahrifinoza
    fahrifinoza Member
    Aug 2015
    30
    jakarta
    When you mounted new plate
    One roller will push the plate
    Position betwen cyl plate and cyl blanket
  8. Mehanka Abortmaher
    Mehanka Abortmaher Senior Member
    Apr 2022
    155
    Russia
    @jham
    I will assume that the error of pneumatics, the cylinder does not reach the magnetic sensor of the piston position. This is usually caused by dust entering the check valve of the pneumatic cylinder speed regulator. The root cause of the clogging of the entire pneumatic system is an oil-free piston compressor of compressed air located at the sheet feeder. We are tired of constantly cleaning the pneumatic system, changing valves and cylinders. Moving the compressor to the "clean zone" will remove some of the problems.
