Ryobi 524 H double, triple sheets
Discussion in 'Ryobi Printing Presses' started by Ken Hew, Jan 30, 2018.
  1. Ken Hew
    Ken Hew New Member
    Jan 2018
    New York
    I having double sheets when feeding. It was run good for last job and is a same type and size off paper.
    But today i having this for all days. can't run the press at all. I have a problem of the feeder drive. one of the screw is missing i replace it than it keep having this double or triple sheets. NEED HELP.....PLEASE.
  2. jef
    jef Member
    Oct 2015
    36
    canada
    what kind of stock are you running?
  3. Ken Hew
    Ken Hew New Member
    Jan 2018
    New York
    Thanks for reply. I'm running 24LB uncoated text. I been try to lower the paper pile and less sucker air. it still the same.
    Well i'm new on this press but i do run 20LB paper before too.
  4. jef
    jef Member
    Oct 2015
    36
    canada
    might have to balance your air blast,less at the front more at the back or middle.
  5. Ken Hew
    Ken Hew New Member
    Jan 2018
    New York
    Yes I do that too. I thinking is that the feeding drive problem? .I just replaced a screw on it may just too tight or too loose.
    I been running really good before.
  6. ryobiTech
    ryobiTech Member
    Nov 2016
    50
    the world
    Which screw did you replace?
  7. Michele
    Michele New Member
    Mar 2018
    4655 E. Patrick Lane
    Not sure if this will work. About a year ago a buddy told me about these suckerfeet, Bigfoot. Most of my jobs run smooth but I have one job I do every other month and it gives me trouble feeding doubles. Since I bought this accessory I have not had issues. Good luck.
  8. Ken Hew
    Ken Hew New Member
    Jan 2018
    New York
    Thanks for all the information. I got it work now.
