Ryobi 3302HA error C-P-1
Discussion in 'Ryobi Printing Presses' started by Mayur Nipane, Feb 12, 2019.
  1. Mayur Nipane
    Mayur Nipane Member
    Nov 2018
    9
    Mumbai, Maharashtra ,India
    I am having an error in my Ryobi 3302HA showing C - P - 1
    L5 D4
    Can anyone help me for this particular problem?
  2. Warren Peace
    Warren Peace Member
    Feb 2019
    9
    Houston, TX
    From what I can see in the manual it seems that any error codes will start with E. C would indicate a cycle, although I can't find any info on those numbers specifically. You can turn off sensors on the bottom delivery/operator side close to the floor but I only suggest it to help figure out what sensor has tripped (if that's the case). Good luck to you.
  3. Mayur Nipane
    Mayur Nipane Member
    Nov 2018
    9
    Thank you sir. I'll try to do that.
  4. Warren Peace
    Warren Peace Member
    Feb 2019
    9
    Houston, TX
    I was just told by another pressman that whatever the problem is it will be on unit 1.
  5. Mayur Nipane
    Mayur Nipane Member
    Nov 2018
    9
    Ok fine. Can this error occur because of too much oil on some micro switch or sensor or in any of the connector?
  6. Warren Peace
    Warren Peace Member
    Feb 2019
    9
    Houston, TX
    Not to my knowledge, but anything is possible. Did it occur after maintenance or any event like a misfeed?
  7. Mayur Nipane
    Mayur Nipane Member
    Nov 2018
    9
    Machine was working properly before that error occured. There was no misfeed done.
  8. Warren Peace
    Warren Peace Member
    Feb 2019
    9
    Houston, TX
    Best info I can give you at this point if you don't already have it is the phone number on the back of the manual. (800) 752-5139 or (847) 779-1900 or fax (847) 647-6940. Could also be a power surge that did something to a board or you might have lost a breaker and are only getting enough power to turn on the lights.
  9. Mayur Nipane
    Mayur Nipane Member
    Nov 2018
    9
    I don't have the manual. From where can i get the manual?
  10. Warren Peace
    Warren Peace Member
    Feb 2019
    9
    Houston, TX
    I thought it would be easy to download but apparently not. I'll upload a pic of the pages in the manual here to show what it says about error codes.
  11. Mayur Nipane
    Mayur Nipane Member
    Nov 2018
    9
    Is this pic from service manual or electrical manual?
  12. Warren Peace
    Warren Peace Member
    Feb 2019
    9
    Houston, TX
  13. Warren Peace
    Warren Peace Member
    Feb 2019
    9
    Houston, TX
    I have the numbers of 2 mechanics in the US who could possible do service via phone.
  14. Mayur Nipane
    Mayur Nipane Member
    Nov 2018
    9
    Ok fine. I just found service manual on official website of ryobi press parts.
  15. Mayur Nipane
    Mayur Nipane Member
    Nov 2018
    9
    Hello sir my problem is solved. One of the wire in connector MC90 was short with earthing. That wire was of a limit switch
  16. Warren Peace
    Warren Peace Member
    Feb 2019
    9
    Houston, TX
    That's great. I'm glad you got it up and running correctly. I'll remember this if it ever happens over here.
    Mayur Nipane likes this.
  17. Mayur Nipane
    Mayur Nipane Member
    Nov 2018
    9
    I bypassed that limit switch. I removed that connector & again connected so it was working properly but after sometime again it showed the error. Then i came to know about that wire which was short with earthing so i cut the wire near the connector & bypassed it.
    Warren Peace likes this.
