Deadspread4
I run a Ryobi 3302 M. When I run smaller jobs like business cards, envelopes, or even 8.5 by 11 I have no problem controling ink coverage, except in heavy coverage cases. As soon as I move to larger jobs I start to get image blocking, and text filling in on my sides. After this it is very hard to keep the job dark enough, while also avoiding the blocking and filling.This mainly happens on the operator side, most severely on the gripper end. Alot of times it starts to manifest itself as a dark triangle appearing in the same corner. My boss thinks I need to work on my ink/water balance better, but im not so sure. I know that my ink keys won't cut the ink flow completely off on the sides, the non operator side of the 2nd units fountain leaks ink little, I can't keep a consistant amount of water on my rollers, and I am skeptical that my ink ductor roller may by warped. When I wash up My ductor roller never come completely clean in the middle and has to be hand cleaned. Im skeptical that this means its not hitting the other rollers properly. Im not sure if any or all of these could be causing my problems, or if I do in deed need to work or my ink/water balance. I was also wondering if anyone else that is running this press could explain how the ink their press up for a run, im an not sure if I am putting the correct amount of ink on my water rollers. All advice is greatly appreciated.
