maltobello
- 2010
- 3
- Boston MA
My company has 17 Canon IR 3220 devices in our offices. These are all installed with ImagePass C1 and C2 RIP's. We have been having issues deploying Windows Vista because we are not able to get stable, up to date Postscript drivers for the devices. We are also looking at deploying Windows 7, 64 bit and there are no Postscript drivers available for these devices on this platform. At this point our options are:
1.Use PCL drivers which support Vista 32 bit and 64 bit platforms. Presumably these will also work on Windows 7.
2.Bypass/remove the C1 and C2 RIP's on these devices. Windows 7 32 and 64 bit drivers (Postscript) are available for this configuration.
We have tried the PCL drivers in the past, but our graphic designers were not pleased with the output. Not sure if settings could be adjusted to achieve something they would be OK with (I work for a Civil Engineering Consultant, we have 800+ people, probably 25 graphic designers). My understanding if we remove the RIP is that print speed will improve, but quality will suffer.
Can any of you weigh in on what we should expect with each of these options? Is there anything else I'm missing that we could try?
Thanks in advance for your help.
