Roland r706 installer problem
Discussion in 'Man Roland Printing Presses' started by BennyAyung, Jun 14, 2025.
  1. BennyAyung
    BennyAyung Member
    Jul 2024
    23
    Jakarta, Indonesia
    I have problem with my disk installer, advice please
    My machine is roland R706+LV
    Thanks before
  2. matthias76
    matthias76 Member
    Nov 2016
    43
    Germany
    Wrong disk, corrupt disk !?
  3. BennyAyung
    BennyAyung Member
    Jul 2024
    23
    Jakarta, Indonesia
    But when I check it and open with msdos the all files and folder its fine and can read normally
  4. Sergey_Ivanov_1963
    Sergey_Ivanov_1963 Member
    Apr 2025
    6
    Russia
    When installing LEITSTAND, do not use the MMS disk. Judging by the photo, you need to insert a language disk or a configuration disk
  5. Sergey_Ivanov_1963
    Apr 2025
    6
    Russia
  6. drukman
    drukman Senior Member
    Mar 2016
    435
    Bulgaria
    Never put original Roland disks into a Windows computer. Diskettes are formatted differently and have hardware copy protection. If a disk fails the check, it can only be repaired with a specially written program, or a new one can be purchased from Roland. Any attempt to restore it with DOS or WINDOWS programs will result in destruction.
    The diskette in the photo is normal to give such a message if it is used to install the RCI program. It is used ONLY to reinstall the MMS firmware.
  7. Daniel.Sanchez
    Daniel.Sanchez Senior Member
    Apr 2020
    171
    peru
    You can try it with another version, v20.03
  8. BennyAyung
    BennyAyung Member
    Jul 2024
    23
    Jakarta, Indonesia
    So what disk should i use, can you give me the disk sequence
    I'm did it with this sequence :
    1. Disk leitstand 1, 2 and 3 then
    2. Disk sprachen deutsch and then sparchen english
    3. Disk sps-mms-config
    4. Disk machine number
    Is it right...?
    Cause when in step 3, i got message like the picture i sent
  9. drukman
    Mar 2016
    435
    Bulgaria
    Step 3 should be machine configuration. The diskette has the machine number. Not MMS config.
    As Sergey has shown above
  10. Asim Shehzad
    Asim Shehzad Senior Member
    Feb 2021
    126
    Lahore, Pakistan
    Don't use the SPS-MMS config disk unless you are going to install the MMS program
  11. BennyAyung
    BennyAyung Member
    Jul 2024
    23
    Jakarta, Indonesia
    Ok, i will try again
    Thanks u very much
  12. BennyAyung
    BennyAyung Member
    Jul 2024
    23
    Jakarta, Indonesia
    It's work, i pass the step 3 as sugested and runing well
    Thanks all
