Replacing laser diode with used one
Discussion in 'DI Presses' started by Richard_Hardin, Nov 8, 2017.
  1. Richard_Hardin
    Richard_Hardin Member
    Jul 2015
    21
    Eureka, CA
    I am in the works of replacing a couple of laser diodes on our QMDI Pro. I am more or less winged it the last couple of times, but now that I replacing a couple more, what is the correct number to use as the new identification number for diode? It looks like it accepts a 3 digit code, but I'm not finding a definitive number from the diode. For used diodes, is there a starting number that i can use as a base number and then adjust the diode manually from there? Any help on this matter would be appreciated. diode.jpg
  2. Paul Cavanaugh
    Paul Cavanaugh Senior Member
    Dec 2009
    630
    Kennesaw, GA
    Typically there was a label on the diode with a power value written on it when you bought a new one. The ones that came in the press did not have any values on them because they were set in the imaging head. It is really just a crapshoot where you start with the number. You can look at what the average is of the ones that are working in the imaging head and start with that as a value.
  3. augustov
    augustov Senior Member
    Aug 2011
    176
    Colombia
    Put in low value and make adjustment for burn setting, i have diode for sell very cheap, if you need i have almost 20 diode laser for sell.
