Replace Waste Dry Ink Filter
Loss of vacuum to the cleaner. Could be a faulty cyclone blower
Mark
  • crap i have this. igen has been more productive than ever as of late....
    thoughts?
    I have a thought but use at your own risk disconnect the black hose that runs from the cleaner unit to the cyclone blower drop in a handful of rice and reconnect hose clamp and close door let in run for a hour or so once you open the door up again the rice will drop into the waste toner box. that will knock the toner off the walls of the tubes. If that does not fix the problem there is a sensor on top of the cyclone tube with small hose running into it . check make sure that tube is not plugged and replace sensor. best of luck
    LOL im just gonna do that so I can say I put food inside the Igen.
    nah. the thing runs perfectly fine day in day out...
    i go to put this ONE bottle in, and it wont clear. bottle is on the shelf... not sure I care anymore :)
    too funny..just had this..we almost never have to replace that filter!!!... I got away with a re-boot LOL
    how?
    mine is dark purple all the time lol. loaded with waste toner.
    OK. well. just got through all the fuser problems... and BAM
    im having this again. ugh. replace waste dry ink filter. its new, semi clean. ive even vacuumed it.
    is there a switch to kill that reminder for a few hours?
    took off that little switch/relay thats on the little hose.... blew it out...blew out the hose...
    made a huge pink cloud. LOL
    its running
    that quote.... not relevant. was thinking we were talking about my faulty developer waste bottle. sorry
    what kind of rice should I use? uncle bens? brown or white? mexican?
    My igen3 has been doing this too. New filter, same story. I messed with the sensor and got it to go away temporarily, but it came back. Blew out that hose, 'twas clean already. Suggestions?
  • the little sensor on the end of that hose....take the hose off. blow it out. then take sensor off and blow into it. tap it with a screwdriver a few times.
    worked for me.
    There is a sensor switch in the filter chamber, make sure its clear and clean.
