Quin would like to know can help me with the replacement of L268 FBN transistor with a source of a Lamda quikmaster di 46 rear that I thank you very much in advance to partner, to help me
I am repairing a source of a lambda quikmaster di46 not meeting specifications transistor L268 FBN if someone has this transistor specification or already had the same problem I would like
i need fbn l268 if I installed a DI in bogota colombia quikmaster but the source of 12 V is shorted and needs replacement transistor FBN L268 replacement or data in advance thank you very much
If this is the SOURCE LAMBDA mode lfs 50-12. 4 FBN L268 TRANSISTOR AND NOT WITH THE SPECIFICATIONS FOR CHANGE
im not understanding you...........where is this part located on the press? Is it inside the big "pretty" gold (box power supply) in the front of the console........
