Raising ink/tone % for offset job
Discussion in '4-Color Offset Presses +' started by Adam Wentworth, Aug 10, 2017.
  1. Adam Wentworth
    Adam Wentworth New Member
    Aug 2017
    Massachusetts
    Hi,
    I'm working on a CD/LP packaging job and just received this message from the printer:
    "Please Note: The textured background image being used on your digipak and insert has only 3% tone in its darkest areas. Offset printing plates cannot hold a consist tone below 5% for C-M-K and 10% for Y. As a result, your background texture may either blowout to white or have an inconsistent and speckled appearance on your final print."
    I've never run into this issue before, and as I admittedly don't do much print work these days, I'm at a bit of a loss as to how to correct this without changing the overall image that much.
    For context, the artwork is a charcoal illustration. It was done on paper stock with a nice tooth, and I'm trying to keep the texture of the paper visible as a BG for the entire piece. This texture is the issue in question, and it is quite subtle.
    Any advice on how to adjust the files to appropriate levels without completely crushing the main, much darker illustration would be wonderful. Thanks for your time.
  2. turbotom1052
    turbotom1052 Senior Member
    Oct 2008
    836
    Vermont
    Im no pre press guy but doesn't your software allow for a localized bump in the highlight of each of the colors?
  3. alibryan
    alibryan Senior Member
    May 2014
    151
    Pacific NW
    This is false. If offset printing plates were unable to hold anything less than a 5% dot, FM screening wouldn't even exist. Chances are, your printer is using AM screening and a line screen that is too low (not fine enough) for consistent, fine detail printing.
  4. aqazi81
    aqazi81 Senior Member
    Oct 2009
    826
    KARACHI PAKISTAN
    Agree with you alibryan.
