R700 First ink form roller jumps on the operating side
Discussion in 'Man Roland Printing Presses' started by matthias76, Aug 14, 2022.
  1. matthias76
    matthias76 Member
    Nov 2016
    42
    Germany
    The first ink form roller jumps on the operating side.
    When I look through the cover on printing press at the first form roller, it moves too much and jumps a little.
    The roller has no contact to the plate and cannot be adjusted.
    I have removed it and measured 70mm.
    The roller lock closes very easily just so engages.
    The roller mount does not move much, I thought it was something broken. I have found nothing.
    I put everything back together and adjusted.
    Roller could also be adjusted to the plate. Thought the problem was solved......but no
    Do you have any ideas?
    R700 year 2000
  2. Adil
    Adil Senior Member
    Nov 2021
    1,319
    Casablanca
    Could be a bearing problem
  3. matthias76
    matthias76 Member
    Nov 2016
    42
    Germany
    The bearing of the roller seems ok.
  4. drukman
    drukman Senior Member
    Mar 2016
    419
    Bulgaria
    Remove the bridge (tandem) roller and try.
  5. matthias76
    matthias76 Member
    Nov 2016
    42
    Germany
    Does it work without tandem ?
    What will i see ?
  6. Jack liston
    Jack liston Senior Member
    Sep 2019
    326
    Connecticut
    If bridge is too tight it will cause bounce.
